Very slow clock should be constraint as false path?
- 2 years ago
The problem is that you are using DONE as a clock signal. It's not. You should just create combinatorial logic or better yet synchronize the loading of word with clk.
always @(negedge clk) begin if (reset) begin word<=0; end else if (DONE && clk_enable) begin word<=tmp[7:0]; end end
You could use a counter to keep track of a signal level for multiple clock cycles. Or you could use a multicycle timing exception to have the timing analysis extended an extra cycle if you can't change the design.
Hi Sstrell
1-"You could use a counter to keep track of a signal level for multiple clock cycles"-->that not sure how, my FSM is sampling the 1200baud data for each 1200Hz clock enable pulse (one 50MHz clock every 1200Hz) .
2-"Or you could use a multicycle timing exception to have the timing analysis extended an extra cycle if you can't change the design"-->in my case as u see my capture window is half 50Mhz clock, FSM samples on rising edge and capturer on falling edge, so cannot apply multicycle between both modules.
JFYI let u the simple FSM code, u can see what i mean.. For your porpossal might need to modify FSM increasing number of states it stays as GO=0 and GO=1, sampling several clock cycles like a sequence detector, ie: detect 2 zeroes triggers start bit then move to state RUN...?. Of course would need also to enlarge the clock enable width for the appropiate window... lets say... 4X50MHz clk´s each 1200Hz...
Now FSM is just simple IDLE<-->RUN...
As u see im just trying to learn and enhace, even timing is acceptable around 112MHz, slack is also ok...
Thanks for your share and time in advance!.
BR
- FvM2 years ago
some improvements suggested. Presume rs232 input data is asynchronous to FSM clock. Then a certain rate of FSM failure must be expected, worst case a non-recoverable transition to an illegal state. It's necessary to add a synchronizer register chain for data.- Armando19892 years ago
Hello FVM
No worries, rs232 input signals are pass trough 2 flop synchronizers, just are spare modules outside.
Br
