12 years ago --- Quote Start --- Error (10137): Verilog HDL Procedural Assignment error at expr.v(15): object "pwm" on left-hand side of assignment must have a variable data type --- Quote End --- If you don't manage to learn Verilog syntax from the bottom, you should at least read error messages thoroughly. An output port that is assigned in a procedural statement must be defined as reg, e.g.
output reg pwm; or output pwm;
reg pwm;
