11 years agoVerliog - & and | operations backwards?
I am learning Verilog and at a stage in which I would like to see some results from my dev board. I have started with a very simple program which takes two inputs and uses the "&" function to outp...
11 years agoOne thing I noticed is that you are using posedge clk but you are using blocking assignment. Did you supply clock to your module?
You can try: always @ (in_1, in_2) begin out_1 = (in_1 & in_2); end or if you have a clock supplied: always @ (posedge clk) begin out_1 <= (in_1 & in_2); end
