12 years agoThis came up for me around a year ago. It took a while to track it down to being a Quartus problem since the simulations passed and there were no errors or warnings in Quartus. When I mentioned it to an field applications engineer (not a direct Altera FAE, rather a local distributor FAE who happens to cover Altera), the response was "well, don't write your code like that."
--- Quote Start --- The obvious workaround is to convert the port to a wire, then use an explicit assign from a register declared internally. --- Quote End --- Personally, I go with initial statements because the meaning and intention are a little clearer to me. Initial statements are supported by Quartus.
module mux8 (
output reg y,
input wire a,
input wire b,
input wire clk);
initial begin
y = 8'd4;
end
always @(posedge clk) y <= a ? y : y + 1;
endmodule
