18 years agoVerilog real functions and compile time
I am trying to write a Verilog module and synthesize it using Quartus II 8.0, but I am running into some issues. I have a function which returns a real value, and takes in real values for argum...
18 years agoMaybe you can help me to understand what the VHDL code does. To my understanding it assigns a 32 bit signed integer value to port y. The value to be assigned is the result of a operation of data type real that is converted to integer before assigning. The verilog code does the same, and it can be systhesized. So, where is the difference?
