No. Most synthesis tools require that all signals data pass through a module port. Hierarchical references that avoid ports are not allowed in RTL coding styles.
SystemVerilog has an
interface construct that allows you to bundle up common signals in a single port declaration. This avoids repeated declaration and connection of signals.
SystemVerilog also has a .* (dot-star) construct that automatically connect signals with ports having the same name.
Suppose your flash_rom declaration looked like this:
module flash_rom (
//Inputs
input OE,
input CE,
input ADDR,
//Outputs
output DATA,
//Flash
output FL_ADDR,
input FL_DQ,
output FL_OE_N,
output FL_WE_N,
output FL_RST_N
assign FL_OE_N = RD || CS;
assign FL_WE_N = 1;
assign FL_RST_N = 1;
assign FL_ADDR = RM_DATA;
assign RM_DATA = FL_DQ;
endmodule
Then your higher level module would look like this:
module gameboycartridge (
//Inputs
input RD,
input WR,
input CS,
input ADDR,
//Outputs
output DATA
//Flash
output FL_ADDR,
input FL_DQ,
output FL_OE_N,
output FL_WE_N,
output FL_RST_N
flash_rom rom (.OE(RD), .CS(ADDR), .*);
endmodule
