14 years agoHi FvM
Of course it can be done your way, but I don't like: 1) having lots of unused virtual pins on my top level and in every partition, the added LE's might be negligible, but as an engineer I simply don't like it. 2) Personally I find this code more readable: --- Quote Start --- comp:interface port map( l o n g l i s t# ifdef dff d end if# ifdef srff s r# endif --- Quote End --- rather then --- Quote Start --- dff: if DFF gnerate comp:interface port map( l o n g l i s t d end generate srff: if SRFF gnerate comp:interface port map( l o n g l i s t s r end generate --- Quote End --- and if you get a 3rd option it's get worse...
