14 years ago --- Quote Start --- What I'm missing in the "--synthesis translate_off " statement is that it is not conditional. It's great if you have a bit of code that you wish to omit under some condition (synthesis verses simulation), but what happens if you want to replace a part of your design with something else? For example lets say I wish to instantiate a DFF instead of SRFF, In that case I will have to define the pins for the SRFF even when I'm using the generate statement for instantiating only the DFF. I can use the same pin names for both components, but for large designs it's confusing, and then you have width mismatch etc. --- Quote End --- There's a few methods that I've used; 1) For simulation vs synthesis
-- altera translate_off
Modelsim only ports or code goes here
-- altera translate_on
-- synthesis read_comments_as_HDL on
-- Quartus-only code goes here (inside a comment block)
-- synthesis read_comments_as_HDL off
2) For variations in hardware functionality I use generics and generate blocks, eg., to select between single-clock or dual-clock FIFOs in a bridge component. 3) For abstraction of components that differ between families, eg. RAM blocks (altsyncram vs lpm_ram_dq), use a component definition in the code, and then a VHDL configuration to map the component to the specific memory type. Cheers, Dave
