Junyong
3 years agoVerilog HDL Modeul instantiation error
Hello all, I'm trying to compile "Stratix 10-Tx PAM4 2x51 Gbps with SMA Design Example 18.1" with my Strati10 Tx Signal Integrity Dev Kit. I got an error message below during compilation: Error(1...
- 3 years agoHi,
guess you are using a newer version than Quartus 18.1? The example design built with 18.1 will probably need IP regeneration or even some modifications to work with newer Quartus versions. Problems of this kind have been frequently reported.
SyafieqS
3 years agoFor example design, you are encouraged to use same version as mentioned to avoid expected issue e.g. IP upgrades and compatibility.
Use different version is at your own responsibility.
May revert to 18.1 per mentioned.
- Junyong3 years ago
Yes. After matching Quartus version to the example file, it was effective.
I faced another issue, but the issue I addressed was resolved.
Thank you very much for your help.
Junyong
