10 years agoverilog HDL error :constant expression cannot contain a hierarchical identifier
Hello everyone!
I got an error message while synthesizing my code in Quartus Prime, it said: verilog HDL error : constant expression cannot contain a hierarchical identifier. The example code is :
interface m_if#(
parameter LEFTPARA_BITW,
parameter RIGHTPARA_BITW,
parameter RESULT_BITW
input bit clk,
input wire rst
logic leftpara;
logic rightpara;
logic res;
modport port(input clk, rst, leftpara, rightpara, output res);
endinterface
module tb_m(
m_if.port p
localparam tmp_resbitw = p.LEFTPARA_BITW > p.RIGHTPARA_BITW ? p.LEFTPARA_BITW : p.RIGHTPARA_BITW;// synthesizer reports error message like above.
wire tmpres = (tmp_resbitw)'(p.leftpara) + (tmp_resbitw)'(p.rightpara);
always_comb begin
if (p.RESULT_BITW > tmp_resbitw) p.res = (p.RESULT_BITW)'(tmpres);// synthesizer reports error message like above.
else p.res = tmpres;
end
endmodule
For I want to use the parameter in module 'tb_m' which is defined in interface 'm_if', how can I work around it?3 Replies
This is legal and works in simulation. I suspect it is not yet supported in Quartus Synthesis tools.
I suspect you are writing this from VHDL. But all you have to do is write
Putting the addition + inside a concatenation {} makes the intermediate result with of addition self-determined, so its length is MAX(L(leftpa), L(rightpa)). See table 11-21 in the 1800-2012 LRM. There's no need to truncate the intermediate result width if it is larger than the final result. Verilog does that silently for you.module tb_m( m_if.port p ); always_comb begin p.res = {pleftpa + p.rightpa}; endmodule - Altera_Forum
--- Quote Start --- This is legal and works in simulation. I suspect it is not yet supported in Quartus Synthesis tools. I suspect you are writing this from VHDL. But all you have to do is write
Putting the addition + inside a concatenation {} makes the intermediate result with of addition self-determined, so its length is MAX(L(leftpa), L(rightpa)). See table 11-21 in the 1800-2012 LRM. There's no need to truncate the intermediate result width if it is larger than the final result. Verilog does that silently for you. --- Quote End --- Hi, Mr.dave_59! Thank you for replying. Does Altera provide any way for us to commit these deficiency?module tb_m( m_if.port p ); always_comb begin p.res = {pleftpa + p.rightpa}; endmodule - Altera_Forum
--- Quote Start --- Hi, Mr.dave_59! Thank you for replying. Does Altera provide any way for us to commit these deficiency? --- Quote End --- Yes. Open a service request. You'll need an Altera account to do that.
