10 years agoverilog HDL error :constant expression cannot contain a hierarchical identifier
Hello everyone! I got an error message while synthesizing my code in Quartus Prime, it said: verilog HDL error : constant expression cannot contain a hierarchical identifier. The example code ...
10 years ago --- Quote Start --- This is legal and works in simulation. I suspect it is not yet supported in Quartus Synthesis tools. I suspect you are writing this from VHDL. But all you have to do is write
module tb_m(
m_if.port p
always_comb begin
p.res = {pleftpa + p.rightpa};
endmodule Putting the addition + inside a concatenation {} makes the intermediate result with of addition self-determined, so its length is MAX(L(leftpa), L(rightpa)). See table 11-21 in the 1800-2012 LRM. There's no need to truncate the intermediate result width if it is larger than the final result. Verilog does that silently for you. --- Quote End --- Hi, Mr.dave_59! Thank you for replying. Does Altera provide any way for us to commit these deficiency?
