12 years agoYou have a couple of issues going on.
In the test bench. W is changing but not clock. So you only get one clock edge per group of W. Is this what you intended? In the source code: R is never set, and since only 1 positive clock edge occurs, not all bits are configured. Add R=4'd0; right after the begin and before the case(state) statement. the second issue is the structure of your case statement: You have:Start: NextState = (W==1)? CarryOne:NoCarryOne;
Start: R=(W==1)? 1'b1:1'b1;
The second "Start" statement never is get ran, since it matches the first one and drops out. This needs to be written as: Start: begin
end for all your case structure. so the finished code should look like:
`timescale 1ns/ 1ns
module excess_three (W,R,clk,Reset);
input W;
input clk;
input Reset;
output R;
reg R;
reg State;
reg NextState;
parameter Start = 3'b000 ,CarryOne= 3'b101, NoCarryOne= 3'b001;
parameter CarryTwo= 3'b011, NoCarryTwo= 3'b111;
parameter CarryThree= 3'b010, NoCarryThree= 3'b110;
always @ (W or State)
begin
R=4'd0;
case (State)
Start: begin
end
CarryOne: begin
NextState = (W==1)? CarryTwo:CarryTwo;
R=(W==1)? 1'b1:1'b0;
end
NoCarryOne: begin
NextState = (W==1)? CarryTwo:NoCarryTwo;
R=(W==1)? 1'b0:1'b1;
end
CarryTwo: begin
NextState = (W==1)? CarryThree:NoCarryThree;
end
NoCarryTwo:begin
NextState = (W==1)? NoCarryThree:NoCarryThree;
end
CarryThree: begin
NextState = (W==1)? NoCarryThree:3'bxxx;
end
NoCarryThree:begin
NextState = (W==1)? Start:Start;
end
endcase
end
always @ (posedge clk or negedge Reset)
begin
if (Reset==0)
State <= Start;
else
State <=NextState;
end
endmodule
