16 years agoVerilog Compiler Differences Quartus / ModelSim
I am not very experienced with HDLs. I am experienced with C, C++, non-procedural languages, logic design, IC design. I do understand that Verilog is not fundamentally procedural, and I do understand the difference between Simulateable and Sythesizable. I am finding differences between the way that Quartus and ModelSim interpret my Verilog. I can get either one to work (albiet a little differently), but not both on the same code. Code Snippets: ----------------------------------------- module Ram_Definition( clk, ...etc.....); parameter ADDRESS_BITS=5; parameter DATA_BITS=2; input clk; ......etc......... reg [DATA_BITS-1:0] mem [(1<<ADDRESS_BITS)-1:0]; .........etc........ ------------------------------------------------------ module Thing(....etc....) Ram_Definition# (.ADDRESS_BITS (5), .DATA_BITS(2)) ram1(.clk (clk), ....etc......); Ram_Definition ram2(.clk (clk), ......etc......) initial begin ram1.mem[16]=2'b00; end ......etc....... -------------------------------------------------------- The above works for ModelSim, and sets ram1.mem[16] to 00, ram2.mem[16] is still xx. This seems correct. Quartus chokes on this. Quartus, instead of ram1.mem[16]=2'b00, wants Ram_Definition.mem[16]=2'b00, and sets both ram1.mem[16] and ram2.mem[16] to 00. ModelSim chokes on this. I have read various texts on Verilog, but have yet to find a formal definition which would cover which of these behaviours is correct, but they are plainly different. Can anyone please explain what I am doing wrong? Thanks, Paul Hilton p.s. Other differences occur when trying to use $readmemb, which works in ModelSim, and Quartus accepts but doesn't actually load the memory (When I run the real hardware). Is it possible that this has something to do with it not actually using RAM for the arrays mem in Ram_Definition? Other differences occur when trying to use parameters not yet declared, e.g. ------------------------------------------------ module Ram_Definition( input clk, input [ADDRESS_BITS-1:0] write_address, .......etc........ ); parameter ADDRESS_BITS=5; .......etc........ ------------------------------------------------- which ModelSim accepts, but not Quartus. (Hence I used the separate name list and type definitions.)
