11 years ago
verilog code problem in VGA 1024x768
module Sungka2(clk,hcount,vcount,hsync,vsync,R,G,B,clk65,clr,lock,lock1,clk32,SW1);
input clk,clr; //input clock 50Mhz
input SW1;
output lock,clk65,lock1,clk32;
output reg  R;
output reg  G;
output reg  B;
output  hcount;
output  vcount;
output hsync, vsync;
reg hsync,vsync,hblank,vblank,blank;
reg  hcount; // pixel number on current line
reg  vcount; // line number
wire hsyncon,hsyncoff,hreset,hblankon; // next slide for generation
wire vsyncon,vsyncoff,vreset,vblankon; // of timing signals
wire next_hb = hreset ? 0 : hblankon ? 1 : hblank; // sync & blank
wire next_vb = vreset ? 0 : vblankon ? 1 : vblank;
//65 Mhz pixel clock
// horizontal: 1344 pixels total
// display 1024 pixels per line
assign hblankon = (hcount == 1023); // turn on blanking
assign hsyncon = (hcount == 1047); // turn on sync pulse 1047
assign hsyncoff = (hcount == 1183); // turn off sync pulse 1183
assign hreset = (hcount == 1343); // end of line (reset counter) 1343
// vertical: 806 lines total
// display 768 lines
assign vblankon = hreset & (vcount == 767); // turn on blanking
assign vsyncon = hreset & (vcount == 776); // turn on sync pulse
assign vsyncoff = hreset & (vcount == 782); // turn off sync pulse
assign vreset = hreset & (vcount == 805); // end of frame
mhz65 (
	.areset (clr),
	.inclk0 (clk),
	.c0 (clk65),
	.locked (lock));
mhz32 (
	.areset (clr),
	.inclk0 (clk),
	.c0 (clk32),
	.locked (lock1));
always @(posedge clk65) begin
hcount <= hreset ? 0 : hcount + 1;
hblank <= next_hb;
hsync <= hsyncon ? 0 : hsyncoff ? 1 : hsync; // active low
vcount <= hreset ? (vreset ? 0 : vcount + 1) : vcount;
vblank <= next_vb;
vsync <= vsyncon ? 0 : vsyncoff ? 1 : vsync; // active low
end
always @(posedge clk) begin
if (vblank | (hblank & ~hreset)) begin
	R <= 8'b00000000;
	G <= 8'b11111111;
	B <= 8'b11111111; end
else begin
	R <= 8'b11111111;
	G <= 8'b11111111;
	B <= 8'b00000000; end
end
endmodule
The problem is it is not displaying a whole cyan or yellow but rather displaying stripes of partially cyan and yellow and green
