14 years ago
Verilog code for memory simulating but not giving output in quartusII
i simulated a verilog code for memory controller in modelsim and it is working fine.But when tested in quartusII 7.2 it simulates but it does not give the desired output as shown in modelsimPE 6.1c.It does not pass the read write signals in quartus.
I'm posting the code below.Plzzzzzzz help.
Verilog code
module main(data_out,iowriteoutput,addr,clock,enable);
input clock,enable;
input[7:0] iowriteoutput;
input [7:0] addr;
output [7:0] data_out;
wire read,write;
control M1(read,write);
mem M2(data_out,clock,enable,read,write,addr,iowriteoutput);
endmodule
module control(read,write);
output reg read,write;
integer i;
initial begin
read=0;
write=0;
for(i=0;i<64;i=i+1)
begin
write=1;
# 10write=0;
read=1;
# 10read=0;
end
end
endmodule
module mem(data_out,clock,enable,read,write,addr,iowriteoutput);
input clock,enable,read,write;
reg[7:0] data_out;
input [7:0] addr;
reg[7:0]tmp[63:0];
always@(posedge clock)
begin
if(enable==1'b1)begin
if(read==1)begin
data_out<=tmp[addr];
end
else if(write==1)begin
tmp[addr]<=iowriteoutput;
end
else begin
data_out<=8'b00000000;
end
end
end
endmodule
1 Reply
    module "control" uses non-synthesizable timed assignments and doesn't generate any output in synthesized design.
