11 years agoVerilog | Instantiating a varied parameter
Hi, I'm working on building an SPI core using verilog, and am running into some problems. My slave device is an ADC with 8 analog channels, of which the user can choose to read from either a ...
11 years agoHi Galfonz,
Thank you for your reply. What do you mean by "You can do calculations with them"? I saw that in System Verilog one can use something which is called 'parameter type' - is it related to my question? Anyways, here is my code for calculating 1's in an input vector: `resetall `timescale 1ns/10ps `define CCT 10 module ones_counter // Port Declarations (input wire aclr_n, input wire clk, input wire [15:0] data, input wire sync_n, input wire fin_read, output reg [2:0] ones_num ); // Internal Declarations wire equ; reg [7:0] data_shift; reg [2:0] ones_cnt; /* --------------------------------------------------------------------------- ****************** counting number of ones in a vector *********************** --------------------------------------------------------------------------- */ always @ (posedge clk, negedge aclr_n) begin if (!aclr_n) data_shift <= 8'b0; else if (sync_n) data_shift <= data[13:6]; else data_shift <= data_shift << 1; end assign equ = (data_shift[7] ^ 1'b0) & (!sync_n); always @ (posedge clk, negedge aclr_n) begin if (!aclr_n) ones_cnt <= 3'b0; else if (equ && data[15]) ones_cnt <= ones_cnt + 1'b1; else if (fin_read) ones_cnt <= 3'b0; end always @ (posedge clk, aclr_n) begin if (!aclr_n) ones_num <= 3'b0; else if (data_shift[7:0] == 8'b0) ones_num <= ones_cnt; else ones_num <= 3'b0; end endmodule I wish to instantiate ones_num register value to my main code. - refael.
