12 years agoVdh: can't determine definition of operator ""-"" -- found 0 possible definitions
My code is the following and I have this error: can't determine definition of operator ""-"" -- found 0 possible definitions. The error is in this line: W(i,j)<=2.25 -(EE(i,j)); At first, instead of using "SIGNED" I had determined all the inputs, output, arrays and variables as STD_LOGIC_VECTOR but I had the same error so I changed them but the error has not bee repaired. Why this error is appeared?What I have to change?Thank you very much in advance.. LIBRARY ieee; USE ieee.std_logic_1164.all; --USE ieee.std_logic_arith.all; --USE ieee.std_logic_unsigned.all; use ieee.numeric_std.all; USE ieee.std_logic_signed.all; ENTITY multiplier IS GENERIC ( bits: INTEGER := 5; --# of bits per word words: INTEGER := 25); --# of words in the memory PORT ( clock:IN STD_LOGIC; z:IN SIGNED(2 DOWNTO 0) :="001"; b:OUT SIGNED(7 DOWNTO 0)); END multiplier; ARCHITECTURE behavior OF multiplier IS TYPE vector_array IS ARRAY (1 TO bits, 1 TO bits) OF SIGNED(3 DOWNTO 0); TYPE vector_array2 IS ARRAY (1 TO bits, 1 TO bits) OF SIGNED(7 DOWNTO 0); SIGNAL memory: vector_array := (("0000", "0001", "0000","0000","0000"), ("0000", "0000", "0001","0000","0000"), ("0001", "0001", "0001","0000","0000"), ("0000", "0000", "0000","0000","0000"), ("0000", "0000", "0000","0000","0000")); SIGNAL N : vector_array ; SIGNAL X : vector_array ; SIGNAL EE : vector_array2 ; SIGNAL W : vector_array2 ; BEGIN PROCESS(clock,memory,N) CONSTANT k : INTEGER:=1; CONSTANT m : INTEGER:=5; VARIABLE l : SIGNED(3 DOWNTO 0); VARIABLE r : SIGNED(3 DOWNTO 0); VARIABLE t : SIGNED(3 DOWNTO 0); VARIABLE d : SIGNED(3 DOWNTO 0); VARIABLE e : SIGNED(3 DOWNTO 0); VARIABLE f : SIGNED(3 DOWNTO 0); VARIABLE g : SIGNED(3 DOWNTO 0); VARIABLE h : SIGNED(3 DOWNTO 0); BEGIN FOR i IN 1 TO 5 LOOP FOR j IN 1 TO 5 LOOP IF(i=k AND j=k) THEN l:=memory(i,m); r:=memory(i,j+1); t:=memory(m,j); d:=memory(i+1,j); e:=memory(m,m); f:=memory(m,j+1); g:=memory(i+1,j+1); h:=memory(i+1,m); ELSIF(i=k AND (j>k AND j<m)) THEN l:=memory(i,j-1); r:=memory(i,j+1); t:=memory(m,j); d:=memory(i+1,j); e:=memory(m,j-1); f:=memory(m,j+1); g:=memory(i+1,j+1); h:=memory(i+1,j-1); ELSIF(i=k AND j=m) THEN l:=memory(i,j-1); r:=memory(i,k); t:=memory(m,j); d:=memory(i+1,j); e:=memory(m,j-1); f:=memory(m,k); g:=memory(i+1,k); h:=memory(i+1,j-1); ELSIF((i>1 AND i<m) AND j=k) THEN l:=memory(i,m); r:=memory(i,j+1); t:=memory(i-1,j); d:=memory(i+1,j); e:=memory(i-1,m); f:=memory(i-1,j+1); g:=memory(i+1,j+1); h:=memory(i+1,m); ELSIF(i=m AND j=k) THEN l:=memory(i,m); r:=memory(i,j+1); t:=memory(i-1,j); d:=memory(k,j); e:=memory(i-1,m); f:=memory(i-1,j+1); g:=memory(k,j+1); h:=memory(k,m); ELSIF(i=m AND (j>k AND j<m)) THEN l:=memory(i,j-1); r:=memory(i,j+1); t:=memory(i-1,j); d:=memory(k,j); e:=memory(i-1,j-1); f:=memory(i-1,j+1); g:=memory(k,j+1); h:=memory(k,j-1); ELSIF(i=m AND j=m) THEN l:=memory(i,j-1); r:=memory(i,k); t:=memory(i-1,j); d:=memory(k,j); e:=memory(i-1,j-1); f:=memory(i-1,k); g:=memory(k,1); h:=memory(k,j-1); ELSIF((i>1 AND i<m) AND j=m) THEN l:=memory(i,j-1); r:=memory(i,k); t:=memory(i-1,j); d:=memory(i+1,j); e:=memory(i-1,j-1); f:=memory(i-1,k); g:=memory(i+1,k); h:=memory(i+1,j-1); ELSE l:=memory(i,j-1); r:=memory(i,j+1); t:=memory(i-1,j); d:=memory(i+1,j); e:=memory(i-1,j-1); f:=memory(i-1,j+1); g:=memory(i+1,j+1); h:=memory(i+1,j-1); END IF; N(i,j)<= (l+r+t+d+e+f+g+h); X(i,j) <= memory(i,j)+(N(i,j)+N(i,j)); EE(i,j)<=(X(i,j)-6)*(X(i,j)-6); W(i,j)<=2.25 -(EE(i,j)); END LOOP; END LOOP; FOR i IN 1 TO 5 LOOP IF(z=i) THEN b<=EE(i,i); END IF; END LOOP; END process; END behavior;
