eman_delete
3 years agovcs simulation scripts generation
I have the atan IP as part of my quartus project. The IP simulation script generated for vcs doesn't use any atan.vho file. It uses the atan.vhd file (same for mentor, cadence). I also see atan.vhd...
RichardT_altera
3 years agoIt appears that there may be an issue with the simulation flow. I assume that you are using the scripted simulation flow.
You can refer to the document below for guidance on setting up the VCS simulation:
Do you able to simulate it using Questa Intel FPGA Edition before? You may checkout the User Guide below for instructions on running the simulation with Questa Intel FPGA Edition.
The scripting concept is similar to VCS.
https://www.intel.com/content/www/us/en/docs/programmable/691278/21-3/quick-start.html
Richard Tan
p/s: If you find any answers from the community or Intel Support to be helpful, we encourage you to mark them as the best answer or rate them 4/5 in the survey.
