9 years agovariable initialization help
Hi all, For a process, the variable only take the initial value at the first time the process is running, then it will take the last value of that variable. I am wondering how can I initial the...
9 years agoMany thanks for your help!
For the example I have above, where to initialize the signal v1?
ENTITY example IS
PORT (
clk : IN STD_LOGIC;
initval : IN INTEGER;
END ENTITY;
ARCHITECTURE rt OF example IS
SIGNAL v1 : INTEGER := initval; ------------------------- If I initialized here
ex: PROCESS (clk)
BEGIN
IF (rising_edge(clk)) THEN
IF (v1 < 100) THEN
v1 <= v1 + 1;
END IF;
END IF;
END PROCESS;
END ARCHITECTURE;
If I initialized there, suppose I input 1 on port initval at clock edge 1, and the v1 will keep increase until 100 at every clock edge. However, if I input a new value at some other clock edge, how does this will effect the process?
