14 years agousing VHDL record type as port
Hi
In order to improve readability I want to use record types for buses so when I have a bus traversing across hierarchies, instead of declaring and mapping all of the signals, I will do it once for the bus. Let's say I have an SPI master wrapped inside my top level entity (or even further down the hierarchy). So I define an SPI bus --- Quote Start --- type SPI_bus is record clk : STD_LOGIC; cs: STD_LOGIC; master_data: STD_LOGIC; slave_data: STD_LOGIC; end record; --- Quote End --- I want to avoid declaring separately clk cs master_data as outputs and slave_data as input, for my top level entity. is there a way to do it, other the defining a type for outputs and a type for inputs? maybe adding something to my type declaration? Thanks in advance.
