14 years ago
Using to many M9K
I recently decided, that my intermediate storage is not sufficient, and I need to double the size. I wanted to upgrade from
RAM_1w1r_1024x18 (using 2 instances of M9K)
to
RAM_1w1r_2048x18 (using 4 instances of M9K)
However, when trying to generate the block memory using the megawizzard, it always uses 5 instances of m9k.
What's happening here? To my understanding, it should assemble four times an M9K in 512x18 mode? What did I miss?
    By default, memory blocks are configured into the max depth to support what you need, so they would be build in 2Kx4 mode, hence needing 5 blocks. (This is faster since the outputs don't need to be muxed). THe MAX_RAM_DEPTH parameter can be set to 512, in which case it will stitch 512x18s together vertically.
