17 years ago --- Quote Start --- Hi, I recently recieved a 10 day evaluation license for Synplify Pro 9.6.1. What I was planning to do was run Synplify Pro from within Quartus and look at the output of the timing analyzer to see if the timing problems I have been having have improved. Anyway turns out that when I attempt to synthesize the design in Quartus I get an error saying: Error: Synthesis tool <None> is not supported by NativeLink Error: NativeLink flow failed to complete synthesis. After doing a bit of reading I found that: "Running the Synplify software through Natvelink integration requires a floating network license (as opposed to a node-locked single-PC license), because batch mode compilation is supported only with floating licenses." I believe I have a node-locked license, so do i need to call them and ask for a floating license? I ask because I am not sure why in the Quartus error it says "Synthesis tool <None>", as if I have not set it up properly. Is there another way to see any potential benifits of synplify other than running it through Quartus? If I run the design through synplify only, then synplify cannot be guided by any constraints that were put in place in the assignment editor, is this correct? Would I need to re constrain the design using synplify if I wanted to synthesize directly through synplify. I know its a basic question and I´m probably doing something wrong, but I´m new to this particular aspect. As always your help is much appreciated. Thanks --- Quote End --- Hi Ardni, you can run SynplifyPro stand-alone. SynplifyPro generates a vqm-file, which you can use as design file Quartus. In EDA settings you have to choose SynplifyPro as synthesis tool. Assignments -> EDA tool settings -> DesignEntry/Synthesis -> SynplifyPro
