thanks for sharing
--- Quote Start --- https://www.altera.com/support/support-resources/download/os-support.html Try check this out... only V14.0 start to support for window 8.1, and if you need for modelsim. a window 8.0 is needed. My take is please forget about window 8.1, and keep your self with windows 7 for best usage. --- Quote End --- Useful link. Thank you. - Altera_Forum
there is no need to stay in an older version anymore and headache for compatibility issues.. Let go get Quartus 15.0 !
--- Quote Start --- https://www.altera.com/support/support-resources/download/os-support.html Try check this out... only V14.0 start to support for window 8.1, and if you need for modelsim. a window 8.0 is needed. My take is please forget about window 8.1, and keep your self with windows 7 for best usage. --- Quote End --- Good information!!!! - Altera_Forum
If you can migrate your design to 15.1 that would be good. Can have lesser bug as well. Unless your device is not supported in the latest QII.
I personally think that maybe you go for 15.0 first... at least when you face anything or issue, you may get some faster patch or those issues had been discovered. I mean if compare with 15.1, those issue maybe new and need more time for root causing.
This is just my 20 cent, as i always believe newer software does not mean is the best, as software defects still may be injected into the new version during fixing the older one. to the second newest quartus always my choice,
--- Quote Start --- This is just my 20 cent, as i always believe newer software does not mean is the best, as software defects still may be injected into the new version during fixing the older one. to the second newest quartus always my choice, --- Quote End --- This practice is quite superb.. it can always maintain a saver distance. Thanks for the idea ! - Altera_Forum
i always believe the second newest version may come with more patch and more discovered issues,
Probably wait for the service pack version.
