12 years agoUsing PLL "lock" signal as the async reset in Verilog
If I want to use the PLL "lock' signal to work as an async reset, the "lock" signal will keep low after the FPGA is powered and goes high after a duration. If I won't reset my PLL, then it means "loc...
12 years ago --- Quote Start --- if there is only low voltage level in "lock", there is no falling edge, whether this lock signal can still trigger the reset or not? --- Quote End --- If you use lock as an active-low reset, and it never goes high, then your logic will remain in reset. Conversely, if you have an active low reset signal, eg., rstN, and it never goes low, the reset condition will never occur. You will see this in simulation, in that a signal will never take on its reset value, but instead will take on the default value for the data type used in the process. In VHDL you can write something like this to set the "power-on" default condition for a signal
signal q : std_logic := '0'; -- power-on condition
signal rstN : std_logic := '1'; -- never asserts low
process(clk, rstN)
begin
if (rstN = '0') then
q <= '0'; -- never occurs
elsif rising_edge(clk) then
q <= d;
end if;
end process;
Verilog will have a similar construct. Cheers, Dave
