12 years agoUsing PLL "lock" signal as the async reset in Verilog
If I want to use the PLL "lock' signal to work as an async reset, the "lock" signal will keep low after the FPGA is powered and goes high after a duration. If I won't reset my PLL, then it means "loc...
12 years agoYou do not want to use PLL lock as a reset signal directly. Not all PLL locked outputs have a debounce/deglitch filter, so they may toggle for a while before they stay in a static state.
Download the code associated with this PCIe test http://www.alteraforum.com/forum/showthread.php?t=35678 There's a deglitch/debounce filter in there you can use to "clean-up" the locked signal. You can then decide whether to use the "clean" signal as a synchronous or asynchronous reset signal. Cheers, Dave
