18 years ago --- Quote Start --- And if the Altera libraries are already come pre-compiled, how do you "point" to them? Is there a ModelSim setup file that is read by vsim? Or would I need to use vmap and vlib? --- Quote End --- Here are a few lines from scripts I used 3 years ago. This might need adjusting. The default directory structure has changed since then.
set ModelSim_OEM_install $::env(MODEL_TECH); # Setting ModelSim_OEM_install to location of ModelSim that is executing this
set ModelSim_OEM_install $ModelSim_OEM_install/..; # script. The ".." is to get above the win32aloem directory.
vlib lpm
vlib altera_mf
vmap altera_mf $ModelSim_OEM_install/altera/vhdl/altera_mf;
vmap lpm $ModelSim_OEM_install/altera/vhdl/220model;
