15 years ago --- Quote Start --- I'm facing a similar kind of problem. I instantiated an altmf_addsub core produced through Megawizard in my design. When I try to simulate this design through Nativelink in Modelsim I get the error in modelsim: Module 'add_subfunc' is not defined. "add_subfunc" is the name I gave to the created core. I used Nativelink feature previously for single precision multiply and it worked flawlessly without any input from me in the modelsim. I'm guessing this has something to do with lpm simulation library, since at the last screen megawizard shows it as a requirement for simulation. --- Quote End --- Hi Guy's, be aware that the LPM's will be no longer supported by Quartus. Quartus 9.1 is the last version which fully support the LPM's. Kind regards GPK
