17 years agoIf I have well understood your problem, you would like to avoid that the bus is held high while waiting for a read ack. While keeping your setting RDACK <= 'Z' you can use an external pull-down resistor to keep the bus low. So you don't need a huge OR gate to read an ack signal in your bus.
Is this OK for you?
