11 years ago --- Quote Start --- use a suitable resolution. fft does not need to be same size as a chunk of data. --- Quote End --- Dear kaz, Thanks for you quickly reply! "suitable resolution" means i just need to select reasonable FFT length, which can recognize all signal frequency spectrum i concern. Am i right? BTW, which IO type i should use in this case? Thanks Jerry
