9 years agoUsing `define constant for decoding address busses
I am trying to make a list of addresses in my project to be use throughout all of my Verilog modules. I have created a "addr.vh" file to put the addresses in as follows: addr.vh `ifndef _addr_vh_ `define _addr_vh_ `define M 'h01808; `endif In a module I trying to store some data when the chip select, write signal and address are true in the follow code: always @ (posedge fpga_clk) begin if (reset_low_sync == false) begin motor_dis_reg <= 'h0000; end else if ((!fpga_cs_low & !rw_low) & (addr == `M)) begin motor_dis_reg <= data_in; end end I keep getting a syntax error# 10170 where I am doing the address comparison with the `M statement. The logic works fine if put the true constant value " 'h01804" instead of the `define M. I though the `define was a one for one substitution? Is this use of `define macro not legal?? Thank you for any reading and any help you may provide! Larry2 Replies
Remove the semicolon at the end of the define directive
--- Quote Start --- Remove the semicolon at the end of the define directive --- Quote End --- Thanks! That fixed it !
