15 years agoIf you are on Windows, an easy hack to use is to use the old "subst" command. Basically, you define a new letter mount to basically link to the different versions of Quartus, such that you can use a constant absolute path to Quartus.
Basically, you can add "z:\quartus\bin" to your search path (PATH) and then, based on the QSF setting, you dynamically change what Z: points to: subst z: c:\acds91_path or subst z: c:\acds100_path such that z:\quartus\bin\quartus*.exe are always the EXEs you use, only they magically point to different versions of Quartus. You use Links to do the same on Linux. Hope this helps. DK
