hi,
I have written a script in ticle (tcl) to create, compile and program the altera's device cyclone II.
First two operations means create and compile design is working fine but when I am adding command to program the device it is showing errors that
"Invalid command name quartus_pgm "
while executing
unknown_original quartus_pgm -c USB-Blaster -m JTAG -o P"
please give me some solution.
the script which I am using is shown below.
basically I want to program the device from the script itself.
load_package flow
project_new test3 -overwrite
# Assign family, device, and top-level file
set_global_assignment -name FAMILY CycloneII
set_global_assignment -name DEVICE EP2C70F896C6
set_global_assignment -name VERILOG_FILE mux2_1.v
set_global_assignment -name TOP_LEVEL_ENTITY mux2_1
# Assign pins
set_location_assignment -to clk Pin_AD15
set_location_assignment -to reset Pin_T29
# compile the project
execute_flow -compile
# Other assignments could follow
quartus_pgm -c USB-Blaster -m JTAG -o P;mux2_1.sof
project_close
