15 years ago
USB Blaster
I have buy a new USB Blaster, the old do not work, how I can do for repearing?? or where is possible to send for repearing??
thanks
Maurizio
    The most common failure on USB blasters in the output buffers chip. You can try and replace it. IIRC it is a 74LVC244
    Thanks in advance, now I find the chip and I replace
    regards
    Maurizio
    I have followed you suggestion, and now the damage USB Blaster working Thanks a lot, I have recovered 300 Euro
    regards
    Maurizio
    Hi all, I have the same problem with my usb blaster rev C, I replaced the LVC244 but the usb blaster don't works yet. Then I checked the LVC244 and found that it have a short between LVC244.19(2OE) and LVC244.10(GND), I checked this line LVC244.19 are in parallel with U9(marking code ZO4G) I suspect a internal damage in IC. Someone can help me to found ic part for U9. It probable a
    single buffer ic?
