13 years ago
USB Blaster ubuntu 12.04
I am running Quartus on linux and I have the DE2 board.
after I clicked on programmer, hardware is being found as USB BLASTER [2-2.2], however when I press start I get :
Error (209053): Unexpected error in JTAG server -- error code 89
Error (209012): Operation failed
Could someone help me with this?
I don't understand a single word of linux! So please consider this while you explaining.
Thanks a lot
    sir,
    I got the same error , where is the mistake ?,kindly any help.I am using 12.04.
    I don't understand linux yet but I think you need to use the superuser
    So go to your folder where quartus file(executable) is located then use
    gksudo ./quartus
    you are prompted to insert your user and password.
    and then everything should be ok!
    But I still don't know why I should have ./ in front of quartos
    I thought to launch a GUI program all I need to do is to use
    gksudo quartus
    Let me know if it helps
    Sir,
    Iam trying to run uclinux on DE0-Nano board, for this i executed the svn co URL command to get the source regarding hardware,but in between server failed(i dint get completel source),what i have to do, i came to know svn co command has to execute only once, my idea is, i will change path and i execute the same URL , the proper output will come or not?,
    Alex.
    --- Quote Start ---
    Its working , thanks a lot.
    --- Quote End ---
    How you fixed the problem?
