14 years agoUSB blaster not recognized in windows 7 32 bit
starting a new thread on this as I didn't see any 32 bit solution in the megathread.
okay I am am running Altera 11.0sp1 build 208. I am using the Quartus II programmer and signal TAP. windows 7 and 32 bit. I see in altera/11.0sp1/qprogrammer/driver/usbblaster/x32 driver is present. I did not add any driver myself. I plug my USB blaster into my board and into my USB, no plug and play message appear. nothing. I start up Signal tap or programmer and try to "add harware". I see options for byte blaster and ethernet blaster. In the "port" section I see "Kernel mode driver not installed". I see the blue LED on USB blaster itself is on so connection is good. any ideas?
