14 years agoI you only installed the Programmer only, then you may need to start the programmer first in order to register into windows correctly.
You may want to double check if the programmer can detect the blaster correctly or not first. Also, if you just installed the programmer, you may want to double check if the path has set correctly in the windows environment variable.
