FrankK
6 days agoUSB-Blaster II malfunction
I’m unable to get a new Altera USB-Blaster II cable working. My setup comprises the Altera 10M08 Evaluation Kit, a Altera USB-Blaster II cable, and Quartus Prime Programmer (Version 25.1std). The US...
FakhrulA_altera
2 days agoHi Frank,
Thank you for the detailed test results.
Since programming succeeds with quartus_pgm, the USB-Blaster II, programming file, and JTAG chain appear functional. The issue is likely related to the Programmer GUI/JTAG server state, combined with the 24 MHz JTAG frequency.
Please try the following:
- Continue using 6 MHz with automatic clock adjustment disabled.
- Close the Programmer, restart the JTAG server, and reconnect the USB-Blaster II.
- Connect the cable directly to the PC and temporarily disconnect other USB-UART or FTDI devices.
- Ensure the USB-Blaster II driver comes from the Quartus Prime Standard Edition 25.1 installation and that drivers from different releases are not mixed.
You may continue using quartus_pgm as a temporary workaround.
References:
Fakhrul
