11 years ago --- Quote Start --- When I plug in my Altera Max II board into my USB slot, it does not install correctly and fails. --- Quote End --- Which MAX II Board? This one? http://www.altera.com/products/devkits/altera/kit-maxii-1270.html The USB connector on this board connects to an FT235B device that you can then access from the MAX II. This is not an on-board USB-Blaster. The kit comes with a USB-Blaster, and that cable should install the drivers under Windows 7 just fine. Cheers, Dave
