CaptainPrice15
2 years agoUSB Blaster disabled in Signal Tap and programmer
Hi all, I am using a ALTERA USB blaster 2 as well as a Terasic Blaster to program Max10 as well as Cyclone10GX devices. I have made sure that the correct drivers for the same have been installed. ...
FvM
2 years agoHi,
more information needed. Is it development board or custom hardware? Is USB Blaster still there when you start Setup dialog again? If not, is JTAG server still running? If not, can it be restarted? (Enter "Services" in Windows Start) Is USB Blaster still visible in Device manager?
Is this happening both with USB Blaster II and Terasic Blaster?
- CaptainPrice152 years ago
Hello!
Thanks a lot for your reply. Below are the details you requested.It is a custom hardware. The USB Blaster is not there when I start the setup dialog. Regarding JTAG server, I did not check if it is running or not. The USB Blaster is always visible in the Device manager.
This happening with both, the USB blaster II as well as Terasic Blaster.
