That sounds brilliant! Can you please provide me with a quick example of scaling coeffs to DAC resolution?
Now just to make sure that I understand the other method (not using a single filter to do it all), I am going to describe how it should be and you tell me if I am right or wrong.
Taking the diagram I attached as a reference:
1- Mapping block will map I/Q to 1 and -1. (If I'm right, how wide this should be?)
2- I think after this stage I need to up-sample by 8 or so. (To the best of my knowledge, this is slightly different from interpolating which invloves filtering)
3- RRC filter will change the shape of the square samples to something more curved. (I don't know it is going to increase the sample rate, i.e. upsample)
4- Interpolate by upsampling (inserting zeros) and filtering, to accomodate mixer rate.
5- Finally upconvert to RF using mixers.
