I appreciate your help, thanks a lot. Actually yes I am still confused so I hope you answer my questions :)
I want to design the whole system in FPGA, so my DAC will produce the RF signal. I have already done FM modulation and now I am working to implement QPSK.
1- I still can't understand why do I need to scale I/Q to DAC resolution? (By the way, does the +1000 represent a DAC resolution in your example?) After mapping I/Q I will multiply them with carriers then sum both arms (I/Q channels) then send the modulated carriers to DAC (Digitally speaking), I think here lies my confusion with what you suggested in the first point in the previous reply.
2- Do you recommend using RRC to handle all of that? I have made a literature review and come out with the attached block diagram.
