14 years agoIf the files did not program in, then the Cong_done should not go high, and the nSTATUS should go low. (assuming you have pull up resistors on them.
Optionally, you can also program a user IO pin to be INIT_DONE, and this will only go high after the FPGA is fully loaded, and has transitioned through Initialization into User Mode (the user design is now running on the FPGA).
