11 years agoWe do use command line scripts. But we migrated the SOPC system into an ASIC. For the most part it depends what you are doing with your scripts. but once you get the SOPC into the QSYS framework I think you are ok, unless you are building the SOPC system via a script, then it's probably more difficult.
Pete
