AEsqu
Contributor
6 years agoupdate_content_to_memory_from_file, support for instance ID name instead of ID number?
Hi, When I upload an HEX or a MIF using the USB BLASTER and the in direct memory editor in batch more (using quartus_stp -t input.txt where input.txt contains begin_memory_edit -hardware_name "US...
JohnT_Altera
6 years agoHi,
You will need to use the "In-System Memory Content Editor" GUI which is part of the Quartus software to determine the Index number for each instant ID. The reason is that the cmd line method is a simplified method to performed which only accept Index number.
You may refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii53012.pdf for more information on how to use the editor.
