9 years agoup counter needs fixing - confused . simple question
Hi, this is a simple counter with asynch pre-set(not wired in diagram), enable, load and synch add +1. i can't figure the trick to get rid of one extra mux column and use the FF enable (where red arr...
9 years ago --- Quote Start --- thats because your enable isnt acting as an enable. cnt_out is a combinatorial version of cnt+1 or cnt, using the enable bit to select. This is because you used a variable for cnt, and then assigned it to a signal after you've done +1 The fix : remove the variable complelely and use signals instead. Switch to vhdl 2008 and replace cnt with cnt_out. Variables can cause these issues as the ordering of the code can affect the circuit. If you used only signals, then you probably wouldnt have had this problem. --- Quote End --- Tricky, I am not sure you are right here. cnt is used before assigning it to itself so a register should be generated for the variable. so enable should work and takes priority over load. I know for sure such counters work with variables. Though I personally use variables very occasionally. I think the problem may be in the last statement outside clk edge.
