15 years agoI don't see an indication, that the said 6 dB loss is caused by the FIR filter. But there seems to be a considerable pass band ripple respectively peaking that can't be explained by a FIR filter characteristic. So I guess there's rather a problem with your measurement setup, that hasn't been described in this post (may be otherwhere?).
Did you perform a measurement without the FIR filter? Do we see simply the 6dB loss from 50 ohm impedance matching?
