10 years agoUnsigned to signed conversion and its simulation in Modelsim
Hello dear friends,
I am having an unsigned number of the input and need to sign extend it and negate (2s representation) if in the specific condition occurs (say if sign=1, to simplify) Here is my code in SystemVerilog: module signed_unsigned ( sign, clk, data_in, data_out); input logic sign; input logic clk; input unsigned [7:0] data_in; output signed [8:0] data_out; always_ff @ (posedge clk) begin if (sign) data_out <= -data_in; else data_out <= data_in; end endmodule It looks like it analyzed properly in Quartus (see RTL representation in the attachment). However, when I simulate in Modelsim it doesn't show the correct result. In the testbench I have a clock generator and just assignments to the data_in. I expect to see 101 value for 0xFF, 156 for 0xAA, etc but nothing happens. the numbers are same What can be wrong? I am very confused. Cheers,3 Replies
I will use signed(for unsigned addt one MSB at zero)
e.g. assuming 8 bit signed: if... data <= input; else data <= -input end - Altera_Forum
This works for me after making one correction unrelated to the signed issue. data_out needs to be a variable in order to make procedural assignments to it. You have it declared as a wire. (you are also using Verilog-1995 style ports, which I updated)
It would have helped to show the testbench you were using. Here is what I used.module signed_unsigned ( input logic sign, input logic clk, input unsigned data_in, output logic signed data_out ); always_ff @ (posedge clk) begin if (sign) data_out <= -data_in; else data_out <= data_in; end endmodule
And the output I gotmodule top; bit clk, sign; logic unsigned data_in; logic signed data_out; always# 5 clk++; initial begin sign=1; data_in = 8'hff; @(negedge clk) $displayh(data_in,,data_out); data_in = 8'hAA; @(negedge clk) $displayh(data_in,,data_out); sign=0; data_in = 8'hff; @(negedge clk) $displayh(data_in,,data_out); data_in = 8'hAA; @(negedge clk) $displayh(data_in,,data_out); $finish; end signed_unsigned su(.*); endmodule : top# Loading work.top(fast) # run -all # ff 101 # aa 156 # ff 0ff # aa 0aa # ** Note: $finish : signed.sv(25) - Altera_Forum
Thank you, dave_59. It is working now! My testbench was a bit crooked too :)
