10 years agoUnsigned to signed conversion and its simulation in Modelsim
Hello dear friends, I am having an unsigned number of the input and need to sign extend it and negate (2s representation) if in the specific condition occurs (say if sign=1, to simplify) Here...
10 years agoThis works for me after making one correction unrelated to the signed issue. data_out needs to be a variable in order to make procedural assignments to it. You have it declared as a wire. (you are also using Verilog-1995 style ports, which I updated)
module signed_unsigned (
input logic sign,
input logic clk,
input unsigned data_in,
output logic signed data_out
always_ff @ (posedge clk) begin
if (sign)
data_out <= -data_in;
else
data_out <= data_in;
end
endmodule It would have helped to show the testbench you were using. Here is what I used. module top;
bit clk, sign;
logic unsigned data_in;
logic signed data_out;
always# 5 clk++;
initial begin
sign=1;
data_in = 8'hff;
@(negedge clk)
$displayh(data_in,,data_out);
data_in = 8'hAA;
@(negedge clk)
sign=0;
data_in = 8'hff;
@(negedge clk)
data_in = 8'hAA;
@(negedge clk)
$finish;
end
signed_unsigned su(.*);
endmodule : top And the output I got # Loading work.top(fast)
# run -all
# ff 101
# aa 156
# ff 0ff
# aa 0aa
# ** Note: $finish : signed.sv(25)
