Unrecognized output fir II
- 3 years ago
When you are using the FIR II IP with Lite edition there will be time limited SOF will generate.
Are you giving any reset to the FIR IP? If Yes, try changing the reset polarity on HW(eg. active low to active high).
Thank you
Kshitij Goel
Please provide initial reset to the FIR II IP for some clock cycles.
Thank you
Kshitij Goel
- tsoundi3 years ago
Hello K**bleep**ij Goel,
I managed to make the fir filter work meanwhile so I am not having an issue anymore. It was a problem with the sink valid pulse that was not initialized correctly.
The issue now is when I try to implement my code on the FPGA itself I don't get any output at all. The testbench works perfectly and all but when loading the FPGA I get zero's at my output. Is it possible that the fir compiler does not work when not having a license I am working on a free version of Quartus prime so maybe that is the issue ?
Thank you,
Daoud
