tsoundi
3 years agoUnrecognized output fir II
Hi, I made a fir filter using the FIR II in the ip catalog of Quartus Prime Lite Edition. When implementing my fir filter I get an Unrecognized signal at the output of the filter. I made a testbe...
- 3 years ago
When you are using the FIR II IP with Lite edition there will be time limited SOF will generate.
Are you giving any reset to the FIR IP? If Yes, try changing the reset polarity on HW(eg. active low to active high).
Thank you
Kshitij Goel
Kshitij_Intel
3 years agoHi,
Can you please try giving the input data from NCO IP and test it.
Thank you
Kshitij Goel
